volume move modify
Modify parameters for a running volume move operation
The volume move modify command modifies the parameters used by the volume move operation in progress. These modified values can be verified by invoking the volume move show command. The volume move operation will use the modified cutover parameters in its next cutover attempt. Note that the modifications to the job are not applied if the move is in the "finishing" state. This command is not supported.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This specifies the name of the volume being moved.
[-cutover-action {abort_on_failure|defer_on_failure|force|wait|retry_on_failure}]- Specified Action For Cutover (privilege: advanced)-
Specifies the action to be taken for cutover. If the effective cluster version is Data ONTAP 8.3 and later, the default is
retry_on_failure; otherwise the default isdefer_on_failure. If theabort_on_failureaction is specified, the job will try to cutover until cutover attempts are exhausted. If it fails to cutover, it will cleanup and end the operation. If thedefer_on_failureaction is specified, the job will try to cutover until the cutover attempts are exhausted. If it fails to cutover, it will move into the "cutover_hard_deferred" state. The volume move job waits for a volume move trigger-cutover command to restart the cutover process. If theforceaction is specified, the job will try to cutover until the cutover attempts are exhausted and force the cutover at the expense of disrupting the clients. If thewaitaction is specified, when the job hits the decision point, it will not go into cutover automatically, instead it will wait for a volume move trigger-cutover command as the signal to try the cutover. [-cutover-window <integer>]- Specified Cutover Time Window (privilege: advanced)-
This specifies the time interval in seconds to completely cutover operations from the original volume to the moved volume. The default value is 30 seconds. The range for valid input is from 30 to 300 seconds, inclusive.
[-enforce-network-throttling {true|false}]- Enforce Replication Engine Node Level Network Throttling (privilege: advanced)-
This specifies whether this move should enforce replication engine node level network throttling. If this parameter is specified with
true, the move will be throttled by the replication engine. The default isfalse.
The following example modifies the parameters for volume move operation on volume vol2.
cluster1::*> volume move show -vserver vs0 -volume vol2
Vserver Name: vs0
Volume Name: vol2
Actual Completion Time: -
Bytes Remaining: 172KB
Specified Action For Cutover: wait
Specified Cutover Time Window: 40
Time Cutover was Triggered: -
Time Cutover was last triggered: -
Destination Aggregate: node_1_aggr1
Destination Node: node_1
Detailed Status: Cutover Deferred, Waiting for user intervention(69.79MB Sent)::Volume move job preparing transfer
Estimated Time of Completion: -
Job ID: 105
Managing Node: node-2
Percentage Complete: 50%
Move Phase: cutover_hard_deferred
Estimated Remaining Duration: -
Replication Throughput: -
Duration of Move: 1 days 00:04
Source Aggregate: node_2_aggr1
Source Node: node_2
Start Time of Move: Sun Sep 18 16:40:37 2011
Move State: alert
cluster1::*> volume move modify -vserver vs0 -volume vol2 -cutover-action abort_on_failure -cutover-window 50
Vserver Name: vs0
Volume Name: vol2
Specified Action For Cutover: abort_on_failure
Specified Cutover Time Window: 50
Job ID: 106
Duration of Move: 1 days 00:05
Source Node: node_2
Move State: alert
The following example shows command failed to modify on vol1 as volume move operation is completed.
cluster1::*> volume move show -vserver vs0 -volume vol1
Vserver Name: vs0
Volume Name: vol1
Actual Completion Time: Sun Sep 18 16:34:27 2011
Specified Cutover Time Window: 30
Detailed Status: Volume move failed because of a job restart
Job ID: 108
Percentage Complete: -
Move Phase: failed
Duration of Move: 15 days 08:07
Source Node: node_2
Start Time of Move: Sat Sep 03 08:27:06 2011
Move State: failed
cluster1::*> volume move modify -vserver vs0 -volume vol1 -cutover-action abort_on_failure -cutover-window 40
Error: command failed: There is no volume move operation running on the specified volume.
