security dynamic-authorization show
Show dynamic-authorization global settings
The security dynamic-authorization show displays information on dynamic authorization settings.
- { [-fields <fieldname>,…]
Selects the fields that you specify.
- | [-instance ]}
Displays all the fields for the dynamic authorization settings.
- [-vserver <vserver name>]- Vserver
Selects the dynamic authorization settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
- [-state {disabled|visibility|enforced}]- Dynamic Authorization State
- [-suppression-interval {P[<integer>D]T[<integer>H][<integer>M][<integer>S] | P<integer>W | disabled}]- Dynamic Authorization Suppression Interval
- [-lower-challenge-boundary <percent>]- Lower MFA Challenge Boundary
- [-upper-challenge-boundary <percent>]- Upper MFA Challenge Boundary
The example below displays information on dynamic authorization settings:
cluster1::> security dynamic-authorization show
Vserver: cluster1
                          Dynamic Authorization State: disabled
           Dynamic Authorization Suppression Interval: 10m
                         Lower MFA Challenge Boundary: 0%
                         Upper MFA Challenge Boundary: 90%
 PDFs
PDFs
