security dynamic-authorization show
Show dynamic-authorization global settings
The security dynamic-authorization show displays information on dynamic authorization settings.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the dynamic authorization settings.
[-vserver <vserver name>]- Vserver-
Selects the dynamic authorization settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
[-state {disabled|visibility|enforced}]- Dynamic Authorization State-
[-suppression-interval {P[<integer>D]T[<integer>H][<integer>M][<integer>S] | P<integer>W | disabled}]- Dynamic Authorization Suppression Interval-
[-lower-challenge-boundary <percent>]- Lower MFA Challenge Boundary-
[-upper-challenge-boundary <percent>]- Upper MFA Challenge Boundary-
The example below displays information on dynamic authorization settings:
cluster1::> security dynamic-authorization show
Vserver: cluster1
Dynamic Authorization State: disabled
Dynamic Authorization Suppression Interval: 10m
Lower MFA Challenge Boundary: 0%
Upper MFA Challenge Boundary: 90%
