ONTAP commands
vserver consistency-group promote
Promote a standalone consistency group to become parent consistency group
The vserver consistency-group promote command can be used to promote a consistency group to a parent consistency group. A new child consistency group will be created and associated with the newly promoted parent consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group that is to be promoted.
-consistency-group <text> - Consistency Group Name
This parameter specifies the consistency group that is to be promoted.
-child-consistency-group <text> - Child Consistency Group Name
This parameter specifies the child consistency group which will get created during promotion.
[-new-name <text>] - New name for the Consistency Group
This parameter optionaly specifies a new name for the consistency group after promotion.
The following command promotes the consistency group singleCG in Vserver vs0, which is renamed to parentCG at promotion gets assigned a new child consistency group childCG at promotion.
cluster1::> vserver consistency-group promote -vserver vs0 -consistency-group singleCG -child-consistency-group childCG -new-name parentCG
        (vserver consistency-group promote)
    [Job 65] Job succeeded: Success
