ONTAP commands
vserver nfs kerberos interface disable
Disable NFS Kerberos on a LIF
The vserver nfs kerberos interface disable command disables NFS Kerberos on a logical interface.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver in which the logical interface exists.
-lif <lif-name> - Logical Interface
This parameter specifies the name of the logical interface on which you want to disable NFS Kerberos.
[-admin-username <text>] - Account Creation Username
This optional parameter specifies the administrator user name.
[-admin-password <text>] - Account Creation Password
This optional parameter specifies the administrator password.
The following example disables NFS Kerberos on a Vserver named vs0 and a logical interface named datalif1.
vs1::> vserver nfs kerberos interface disable -vserver vs0 -lif datalif1
Looking for answers?
Try Doc, our Gen AI Assistant.
