volume rebalance stop
Stop a volume capacity rebalancing operation on a FlexGroup volume
The volume rebalance stop command stops a volume capacity rebalancing operation on a FlexGroup volume in the specified Vserver.
The volume rebalance stop command is only supported on FlexGroup volumes.
-vserver <vserver name>- Vserver Name-
Identifies the Vserver that contains the FlexGroup volume whose capacity rebalancing operation will be stopped.
-volume <volume name>- Volume Name-
Identifies the FlexGroup volume whose capacity rebalancing operation will be stopped.
In this example, a volume capacity rebalancing operation is stopped for the FlexGroup volume "fg1" in vserver "vs0".
cluster::volume rebalance rebalance*> stop -vserver vs0 -volume fg1
