ONTAP commands
storage disk error show
Display disk component and array LUN configuration errors.
The storage disk error show command displays disk component and array LUN configuration errors.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-uid <text>] - UID
Displays the error information of the disk whose unique ID matches the value you specify. A disk unique identifier has the form: `20000000:875D4C32:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 `
[-array-name <array name>] - Array Name
Displays the errors of the storage array whose name you specified.
[-node {<nodename>|local}] - Controller Name
Displays the error information for the disks on the clustered node whose name you specified.
[-disk <disk path name>] - Disk
Displays detailed error information about the disk you specified.
[-serial-number <text>] - Serial Number
Displays the error information for the disk whose serial number you specified.
[-error-id <integer>,…​] - Error ID
Displays the error information for the disks whose Error IDs match IDs you specified.
[-error-type {onepath|onedomain|control|foreign|toobig|toosmall|invalidblocksize|targetasymmap|deviceassymmap|failovermisconfig|unknown|netapp|fwdownrev|qualfail|diskfail|notallflashdisk}] - Error Type
Displays all disk errors of the error types you specified, grouped by type.
  • onepath = The array LUN is accessible only via a single path.
  • onedomain = The array LUN is accessible only via a single fault domain.
  • control = The array LUN cannot be used because it is a control device.
  • foreign = The array LUN is marked as foreign and has some external SCSI reservations other than those from Data ONTAP.
  • toobig = The array LUN exceeds the maximum array LUN size that Data ONTAP supports.
  • toosmall = The array LUN is less than the minimum array LUN size that Data ONTAP supports.
  • invalidblocksize = The array LUN is not a valid block size.
  • targetasymmap = The array LUN is presented more than once on a single target port.
  • deviceassymmap = The array LUN is presented with multiple IDs.
  • failovermisconfig = The array LUN is configured with inconsistent failover methods.
  • unknown = The array LUN from a storage array that is not supported by this version of Data ONTAP.
  • netapp = A SAN front-end LUN from one Data ONTAP system that is presented as external storage to another Data ONTAP system.
  • fwdownrev = The disk firmware is a down version.
  • qualfail = The disk is not supported.
  • diskfail = The disk is in a failed state.
  • notallflashdisk = The disk does not match the All-Flash Optimized personality of the system.
The following example displays configuration errors seen in the system:
cluster1::> storage disk error show
Disk             Error Type        Error Text
1.02.0           qualfail          This disk failed dynamic disk qualification. Update the Disk Qaulification Package.
Looking for answers?
Try Doc, our Gen AI Assistant.
