storage disk error show
Display disk component and array LUN configuration errors.
The storage disk error show command displays disk component and array LUN configuration errors.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-uid <text>]- UID-
Displays the error information of the disk whose unique ID matches the value you specify. A disk unique identifier has the form: `20000000:875D4C32:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000 `
[-array-name <array name>]- Array Name-
Displays the errors of the storage array whose name you specified.
[-node {<nodename>|local}]- Controller Name-
Displays the error information for the disks on the clustered node whose name you specified.
[-disk <disk path name>]- Disk-
Displays detailed error information about the disk you specified.
[-serial-number <text>]- Serial Number-
Displays the error information for the disk whose serial number you specified.
[-error-id <integer>,…]- Error ID-
Displays the error information for the disks whose Error IDs match IDs you specified.
[-error-type {onepath|onedomain|control|foreign|toobig|toosmall|invalidblocksize|targetasymmap|deviceassymmap|failovermisconfig|unknown|netapp|fwdownrev|qualfail|diskfail|notallflashdisk}]- Error Type-
Displays all disk errors of the error types you specified, grouped by type.
onepath = The array LUN is accessible only via a single path.
onedomain = The array LUN is accessible only via a single fault domain.
control = The array LUN cannot be used because it is a control device.
foreign = The array LUN is marked as foreign and has some external SCSI reservations other than those from ONTAP.
toobig = The array LUN exceeds the maximum array LUN size that ONTAP supports.
toosmall = The array LUN is less than the minimum array LUN size that ONTAP supports.
invalidblocksize = The array LUN is not a valid block size.
targetasymmap = The array LUN is presented more than once on a single target port.
deviceassymmap = The array LUN is presented with multiple IDs.
failovermisconfig = The array LUN is configured with inconsistent failover methods.
unknown = The array LUN from a storage array that is not supported by this version of ONTAP.
netapp = A SAN front-end LUN from one ONTAP system that is presented as external storage to another ONTAP system.
fwdownrev = The disk firmware is a down version.
qualfail = The disk is not supported.
diskfail = The disk is in a failed state.
notallflashdisk = The disk does not match the All-Flash Optimized personality of the system.
The following example displays configuration errors seen in the system:
cluster1::> storage disk error show Disk Error Type Error Text ---------------- ----------------- -------------------------------------------- 1.02.0 qualfail This disk failed dynamic disk qualification. Update the Disk Qaulification Package.
