lun bind destroy
Unbind a VVol LUN from a protocol endpoint
Decrement the reference count of the binding between a protocol endpoint and vvol LUN. If the resulting reference count is zero, the binding is removed.
-vserver <Vserver Name>
- Vserver name (privilege: advanced)-
Specifies the Vserver.
-protocol-endpoint-path <path>
- Protocol Endpoint (privilege: advanced)-
Specifies the path of the protocol endpoint LUN. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
. -vvol-path <path>
- VVol Path (privilege: advanced)-
Specifies the path of the vvol LUN. Examples of correct LUN paths are
/vol/vol1/lun1
. [-force <true>]
- If true, unbind the Vvol completely even if the current reference count is greater than 1. The default is false. (privilege: advanced)-
Completely remove the specified binding, regardless of the current reference count.
cluster1::*> lun bind destroy -protocol-endpoint-path /vol/VV2/PE2 -vvol-path /vol/VV2/30dfab -vserver vs1
Remove the binding between the vvol /vol/VV2/30dfab and the protocol endpoint /vol/VV2/PE2 on Vserver vs1.
