storage tape library path show
Display a list of Tape Libraries on the given path
This command displays path information for a tape library and has the following parameters by default:
Node name
Initiator port
Target port
TPGN (Target Port Group Number)
Port speeds
Path I/O in Kbytes/sec
IOPs
[-fields <fieldname>,…]
fields used to be used in this display
[-detail ]
Using this option displays the following:
Target IOPs
Target LUNs
Path IOPs
Path errors
Path quality
Path LUNs
Initiator IOPs
Initiator LUNs
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Controller name-
The name of the clustered node for which information is being displayed.
[-array-name <array name>]
- Library Name-
Name of the storage tape library that is connected to the cluster.
[-target-wwpn <text>]
- Target Port-
Target World Wide Port Name. Port on the storage tape library that is being used.
[-initiator <text>]
- Initiator Port-
Initiator port that the clustered node uses.
[-initiator-side-switch-port <text>]
- Initiator Side Switch Port-
Switch port connected to the clustered node.
[-tpgn <integer>]
- Target Port Group Number-
TPGN refers to the target port group to which the target port belongs. A target port group is a set of target ports which share the same LUN access characteristics and failover behaviors.
[-port-speed <text>]
- Port Speed-
Port Speed of the specified port.
[-path-io-kbps <integer>]
- Kbytes of I/O per second on Path(Rolling Average)-
Rolling average of Kbytes of I/O per second on the library path.
[-path-iops <integer>]
- Number of I/O per second on Path(Rolling Average)-
Rolling average of I/O per second on the library path.
[-initiator-io-kbps <integer>]
- Kbytes of I/O per second on Initiator(Rolling Average)-
Rolling average of Kbytes of I/O per second on the initiator port.
[-initiator-iops <integer>]
- Number of I/O per second on Initiator(Rolling Average)-
>Rolling average of I/O per second on the initiator port.
[-target-io-kbps <integer>]
- Kbytes of I/O per second to Target(Rolling Average)-
Rolling average of Kbytes of I/O per second on the target port.
[-target-iops <integer>]
- Number of I/O per second to Target(Rolling Average)-
Rolling average of I/O per second on the target port.
[-target-side-switch-port <text>]
- Target Side Switch Port-
Switch port connected to the tape library.
[-path-link-errors <integer>]
- Link Error count on path-
Fibre Channel link error count.
[-path-quality <integer>]
- Percentage of weighted error threshold-
A number representing the threshold of errors that is allowed on the path. Path quality is a weighted error value. When the error weight of a path exceeds the threshold, I/O is routed to a different path.
[-path-lun-in-use-count <integer>]
- Number of LUNs in the in-use state on this path-
Number of LUNs on this path.
[-initiator-lun-in-use-count <integer>]
- Number of LUNs in the in-use state on this initiator-
Number of LUNs on this initiator.
[-target-lun-in-use-count <integer>]
- Number of LUNs in the in-use state on this target-
Number of LUNs on this target.
The following example displays the path information for a storage tape library
cluster1::> storage tape library path show Node Initiator Target Port TPGN Speed (KB/s) IOPs --------------------- --------- ----------------------- ------ ------- ------------ ------------ cluster1-01 3d 50050763124b4d6f 61 4 Gb/S 0 0 cluster1-01 0b 510a09800000412d 35 4 Gb/S 0 0 cluster1-01 0b 510a09820000412d 1 4 Gb/S 0 0 3 entries were displayed.
