storage tape library path show
Display a list of Tape Libraries on the given path
This command displays path information for a tape library and has the following parameters by default:
Node name
Initiator port
Target port
TPGN (Target Port Group Number)
Port speeds
Path I/O in Kbytes/sec
IOPs
[-fields <fieldname>,…] -
fields used to be used in this display
[-detail ] -
Using this option displays the following:
Target IOPs
Target LUNs
Path IOPs
Path errors
Path quality
Path LUNs
Initiator IOPs
Initiator LUNs
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Controller name-
The name of the clustered node for which information is being displayed.
 [-array-name <array name>]- Library Name-
Name of the storage tape library that is connected to the cluster.
 [-target-wwpn <text>]- Target Port-
Target World Wide Port Name. Port on the storage tape library that is being used.
 [-initiator <text>]- Initiator Port-
Initiator port that the clustered node uses.
 [-initiator-side-switch-port <text>]- Initiator Side Switch Port-
Switch port connected to the clustered node.
 [-tpgn <integer>]- Target Port Group Number-
TPGN refers to the target port group to which the target port belongs. A target port group is a set of target ports which share the same LUN access characteristics and failover behaviors.
 [-port-speed <text>]- Port Speed-
Port Speed of the specified port.
 [-path-io-kbps <integer>]- Kbytes of I/O per second on Path(Rolling Average)-
Rolling average of Kbytes of I/O per second on the library path.
 [-path-iops <integer>]- Number of I/O per second on Path(Rolling Average)-
Rolling average of I/O per second on the library path.
 [-initiator-io-kbps <integer>]- Kbytes of I/O per second on Initiator(Rolling Average)-
Rolling average of Kbytes of I/O per second on the initiator port.
 [-initiator-iops <integer>]- Number of I/O per second on Initiator(Rolling Average)-
>Rolling average of I/O per second on the initiator port.
 [-target-io-kbps <integer>]- Kbytes of I/O per second to Target(Rolling Average)-
Rolling average of Kbytes of I/O per second on the target port.
 [-target-iops <integer>]- Number of I/O per second to Target(Rolling Average)-
Rolling average of I/O per second on the target port.
 [-target-side-switch-port <text>]- Target Side Switch Port-
Switch port connected to the tape library.
 [-path-link-errors <integer>]- Link Error count on path-
Fibre Channel link error count.
 [-path-quality <integer>]- Percentage of weighted error threshold-
A number representing the threshold of errors that is allowed on the path. Path quality is a weighted error value. When the error weight of a path exceeds the threshold, I/O is routed to a different path.
 [-path-lun-in-use-count <integer>]- Number of LUNs in the in-use state on this path-
Number of LUNs on this path.
 [-initiator-lun-in-use-count <integer>]- Number of LUNs in the in-use state on this initiator-
Number of LUNs on this initiator.
 [-target-lun-in-use-count <integer>]- Number of LUNs in the in-use state on this target-
Number of LUNs on this target.
The following example displays the path information for a storage tape library
cluster1::> storage tape library path show
Node                   Initiator  Target Port              TPGN    Speed        (KB/s)          IOPs
cluster1-01
                       3d         50050763124b4d6f             61   4 Gb/S             0             0
cluster1-01
                       0b         510a09800000412d             35   4 Gb/S             0             0
cluster1-01
                       0b         510a09820000412d              1   4 Gb/S             0             0
3 entries were displayed.
