system controller location-led show
Display the location LED state on controllers
The system controller location-led show
command shows the current state of the location LED. When lit, the location LED can help you find the controller in the data center.
There is a blue location LED on every controller and on the front of the chassis. When you turn on the location LED for either controller, the chassis location LED automatically turns on. When both controller location LEDs are off, the chassis location LED automatically turns off.
After the location LED is turned on, it stays illuminated for 30 minutes and then automatically shuts off.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the location LED on the specified filers.
[-state {on|off}]
- LED State-
Displays the location LED's status.
The following example lists the current state of the location LED:
cluster1::*> system controller location-led show Node Location LED State -------------- ------------------- node1 Off node2 Off
