volume file retention show
Display retention time of a file protected by SnapLock.
The volume file retention show
command displays the retention time of a file protected by SnapLock given -vserver
and -file
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
This specifies the Vserver on which the volume is located having the file in a SnapLock volume. An exact value is required for this parameter.
[-file </vol/<volume name>/<file path>>]
- File path-
This specifies the absolute path of the file in a SnapLock volume. The value begins with /vol/<volumename>. An exact value is required for this parameter.
[-retention-time <integer>]
- Retention Time of the File-
If this parameter is specified, the command displays information only about the file protected by SnapLock that matches the specified
retention-time
. The value represents file retention time in seconds since 1 January 1970 00:00:00. [-formatted-retention-time <text>]
- Formatted Retention Period-
. The expiry date format is <day> <month> <day of month> <hour>:<min>:<sec><year> in GMT timezone taking care of wraparound. A value ofinfinite
indicates that this file has infinite retention time. A value ofindefinite
indicates that this file has indefinite retention time. A value ofunspecified
indicates that this file will be retained forever; however, the retention time can be changed to an absolute value. [-is-wraparound {true|false}]
- Is Retention Time Wraparound-
-is-wraparound
. The value istrue
if the date represented in retention time is in wraparound format. The wraparound format indicates that dates after 19 January 2038 are mapped from 1 January 1970 through 31 December 2002 to 19 January 2038 through 19 January 2071. [-seconds-until-expiry <integer>]
- Seconds until the File Expires-
. The value represents the number of seconds until the expiration time. [-is-expired {true|false}]
- Has the File Expired-
-is-expired
. The value represents file expiration status. The value isfalse
if the file is under active retention ortrue
if the file is past its expiry time.
The following example displays the retention time of the file /vol/nfs1/file1
cluster1::> volume file retention show -vserver vs0 -file /vol/nfs1/file1 Vserver : vs0 Path : /vol/nfs1/file1 Retention Time (Secs from Epoch) : 1439111404 Formatted Retention Time : Sun Aug 9 09:10:04 GMT 2015 Is Retention Time Wraparound : false
