volume file retention show
Display retention time of a file protected by SnapLock.
The volume file retention show command displays the retention time of a file protected by SnapLock given -vserver and -file .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This specifies the Vserver on which the volume is located having the file in a SnapLock volume. An exact value is required for this parameter.
[-file </vol/<volume name>/<file path>>]- File path-
This specifies the absolute path of the file in a SnapLock volume. The value begins with /vol/<volumename>. An exact value is required for this parameter.
[-retention-time <integer>]- Retention Time of the File-
If this parameter is specified, the command displays information only about the file protected by SnapLock that matches the specified
retention-time. The value represents file retention time in seconds since 1 January 1970 00:00:00. [-formatted-retention-time <text>]- Formatted Retention Period-
formatted-retention-time. The expiry date format is <day> <month> <day of month> <hour>:<min>:<sec><year> in GMT timezone taking care of wraparound. A value ofinfiniteindicates that this file has infinite retention time. A value ofindefiniteindicates that this file has indefinite retention time. A value ofunspecifiedindicates that this file will be retained forever; however, the retention time can be changed to an absolute value. [-is-wraparound {true|false}]- Is Retention Time Wraparound-
-is-wraparound. The value istrueif the date represented in retention time is in wraparound format. The wraparound format indicates that dates after 19 January 2038 are mapped from 1 January 1970 through 31 December 2002 to 19 January 2038 through 19 January 2071. [-seconds-until-expiry <integer>]- Seconds until the File Expires-
-seconds-until-expiry. The value represents the number of seconds until the expiration time. [-is-expired {true|false}]- Has the File Expired-
-is-expired. The value represents file expiration status. The value isfalseif the file is under active retention ortrueif the file is past its expiry time.
The following example displays the retention time of the file /vol/nfs1/file1 :
cluster1::> volume file retention show -vserver vs0 -file /vol/nfs1/file1
Vserver : vs0
Path : /vol/nfs1/file1
Retention Time (Secs from Epoch) : 1439111404
Formatted Retention Time : Sun Aug 9 09:10:04 GMT 2015
Is Retention Time Wraparound : false
