      snapmirror flexgroup-epuuid-prefix-prepare-to-downgrade
Prepares the system for downgrade
The flexgroup-epuuid-prefix-prepare-to-downgrade command prepares nodes to downgrade to a release without FlexGroup endpoint prefixed with the group endpoint uuid capability. Prior to disabling the capability, remove all FlexGroup SnapMirror object store relationships which have a source or destination endpoint prefixed with the group endpoint uuid.
The following example disables the FlexGroup endpoint prefixed with group endpoint uuid capability in the local cluster:
cluster1::> snapmirror flexgroup-epuuid-prefix-prepare-to-downgrade
 PDFs
PDFs
