      vserver fpolicy policy delete
Delete a policy
The vserver fpolicy policy delete command deletes an FPolicy policy.
- -vserver <Vserver Name>- Vserver
This parameter specifies the name of the Vserver from which you want to delete the FPolicy policy.
- -policy-name <Policy name>- Policy
This parameter specifies the name of the FPolicy policy that you want to delete.
The following example deletes an FPolicy policy.
cluster1::> vserver fpolicy policy delete -vserver vs1.example.com -policy-name vs1_pol
 PDFs
PDFs
