system switch ethernet log collect-support-log
Initiates the support log collection for the specified Ethernet switch.
The system switch ethernet log collect-support-log command initiates the support log collection for the specified Ethernet switch via SSH.
Log files are removed during takeover or giveback operations. |
-device <text>- Switch Name-
Ethernet switch device for which the support log collection will be performed.
The device must be one of the devices listed as an Ethernet switch from the system switch ethernet show command. The full device name from the system switch ethernet show command must be used.
cluster1::> system switch ethernet log collect-support-log -device cluster-sw1
Initiates support log collection for the specified Ethernet switches.
