storage tape alias clear
Clear alias names
This command clears alias names for a tape drive or media changer.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node to which the tape drive is attached.
-name <text>
- Alias Name That Is to Be Cleared -
Use this parameter to specify the alias name that is to be cleared. You can use the 'storage tape show -alias' command to find more information about alias names of tape drives and media changers attached to a node. The
-clear-scope
and-name
parameters are mutually exclusive. If you specify the-name
parameter, a single alias name is cleared. - |
-clear-scope {tape|media-changer|all}
- Scope of Alias Clear Operation } -
Use this parameter to specify the scope of the alias clear operation. The
-clear-scope
and-name
parameters are mutually exclusive. If you specify the-clear-scope
parameter, multiple aliases are cleared depending upon the value of the parameter.The possible values for
-clear-scope
are as follows:-
tape - Clear all tape drive aliases
media-changer - Clear all media-changer aliases
all - Clear both tape drive and media-changer aliases
The following example clears an alias name 'st3' attached to the node, cluster1-01.
cluster1::> storage tape alias clear -node cluster1-01 -name st3
The following example clears all tape drive alias names attached to the node, cluster1-01.
cluster1::> storage tape alias clear -node cluster1-01 -clear-scope tape
The following example clears all media changer alias names attached to the node, cluster1-01.
cluster1::> storage tape alias clear -node cluster1-01 -clear-scope media-changer
The following example clears both tape and media changer alias names attached to the node, cluster1-01.
cluster1::> storage tape alias clear -node cluster1-01 -clear-scope all
