security login rest-role create
Add a REST access control role
The security login rest-role create
command creates a Representational State Transfer (REST) access-control role. A REST access-control role consists of a role name and an Application Programming Interface (API) to which the role has access. It optionally includes an access level (none
, readonly
, read_create
, read_modify
, read_create_modify
or all
) for the API. After you create a REST access-control role, you can apply it to a management-utility login account by using the security login modify or security login create commands.
-vserver <vserver name>
- Vserver-
This optionally specifies the Vserver name associated with the REST role.
-role <text>
- Role Name-
This specifies the REST role that is to be created.
-api <text>
- API Path-
This specifies the API to which the REST role has access. This API can be a private CLI API or a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
/api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
/api/storage/volumes/{volume.uuid}/files
/api/storage/volumes/{volume.uuid}/top-metrics/clients
/api/storage/volumes/{volume.uuid}/top-metrics/directories
/api/storage/volumes/{volume.uuid}/top-metrics/files
/api/storage/volumes/{volume.uuid}/top-metrics/users
/api/svm/svms/{svm.uuid}/top-metrics/clients
/api/svm/svms/{svm.uuid}/top-metrics/directories
/api/svm/svms/{svm.uuid}/top-metrics/files
/api/svm/svms/{svm.uuid}/top-metrics/users
Ontap S3 APIs
/api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character
could be used in place of{volume.uuid}
or{svm.uuid}
to denoteall
volumes orall
SVMs, depending upon whether the REST endpoint references volumes or SVMs. -
-access {none|readonly|read_create|read_modify|read_create_modify|all}
- Access Level-
This optionally specifies an access level for the REST role. Possible access level settings are
none
,readonly
,read_create
,read_modify
,read_create_modify
andall
The following command creates a REST access-control role named admin
for the vs1.example.com
Vserver. This REST role has an access-level of all
for the /api/storage/volumes
API.
cluster1::> security login rest-role create -role admin -api "/api/storage/volumes" -access all -vserver vs1.example.com cluster1::>
The following command creates a REST access-control role named rest_role1
for the cluster1.example.com
administrative Vserver. This REST role has an access-level of read_create_modify
for the /api/snapmirror/policies
API.
cluster1::> security login rest-role create -role rest_role1 -api "/api/snapmirror/policies" -access read_create_modify -vserver cluster1.example.com cluster1::>
The following command creates a REST access-control role named vs1_role
Vserver. This REST role has an access level of readonly
for all snapshots on the volume with UUID f8a541b5-b68c-11ea-9581-005056bbabe6
. The volume UUID refers to the -instance-uuid
field value in the volume show command output at diagnostic privilege level.
cluster1::> security login rest-role create -role vs1_role -api "/api/storage/volumes/f8a541b5-b68c-11ea-9581-005056bbabe6/snapshots" -access readonly -vserver vs1.example.com Warning: Operating on an alias operates on the target of the specified alias: "volume snapshot" cluster1::>
The following command creates a REST access-control role named vs2_role
for the vs2.example.com
for all files on the volume with UUID 15d489b5-1d40-11ec-992e-005056bba268
.The volume UUID refers to the -instance-uuid
cluster1::> security login rest-role create -role vs2_role -api "/api/storage/volumes/15d489b5-1d40-11ec-992e-005056bba268/files" -access readonly -vserver vs2.example.com cluster1::>
The following command creates a REST access-control role named vs3_role
for the vs3.example.com
Vserver. This REST role has an access level of read_create_modify
for all top-metrics directories on the SVM with UUID 881764b5-9ea1-11ec-8771-005056bb1a7c
cluster1::> security login rest-role create -role vs3_role -api "/api/svm/svms/881764b5-9ea1-11ec-8771-005056bb1a7c/top-metrics/directories" -access read_create_modify -vserver vs3.example.com cluster1::>
The following command creates a REST access-control role named vs4_role
for the vs4.example.com
Vserver. This REST role has an access level of all
for command directory cluster
cluster1::> security login rest-role create -role vs4_role -api "/api/private/cli/cluster" -access all -vserver vs4.example.com cluster1::>
