statistics lun show
LUN throughput and latency metrics
This command continuously displays performance data for LUNs at a regular interval. The command output displays data in the following columns:
Lun - LUN name.
Vserver - vserver name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
Read (Bps) - read throughput in bytes per second.
Write (Bps) - write throughput in bytes per second.
Latency(us) - average latency for an operation in microseconds.
- [-lun <text>]- Lun
Selects the LUN for which you want to display performance data.
- [-vserver <vserver name>]- Vserver
Selects the vserver for which you want to display performance data.
- [-sort-key <text>]- Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
- -interval <integer>- Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
- -iterations <integer>- Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
- -max <integer>- Maximum Number of Instances
Specifies the maximum number of LUNs to display. The default setting is 25.
The following example displays LUN statistics:
cluster1::> statistics lun show cluster1 : 12/31/2013 16:00:04 *Total Read Write Other Read Write Latency Lun Vserver Ops Ops Ops Ops (Bps) (Bps) (us) ---- ------- ------ ---- ----- ----- ------ ----- ------- lun1 vs1 58 13 15 29 310585 3014 39 lun0 vs2 56 0 11 45 8192 28826 47 [...]
 PDFs
PDFs
