ONTAP commands
statistics lun show
LUN throughput and latency metrics
This command continuously displays performance data for LUNs at a regular interval. The command output displays data in the following columns:
  • Lun - LUN name.
  • Vserver - vserver name.
  • Total Ops - total number of operations per second.
  • Read Ops - read operations per second.
  • Write Ops - write operations per second.
  • Other Ops - other operations per second.
  • Read (Bps) - read throughput in bytes per second.
  • Write (Bps) - write throughput in bytes per second.
  • Latency(ms) - average latency for an operation in milliseconds.
[-lun <text>] - Lun
Selects the LUN for which you want to display performance data.
[-vserver <vserver name>] - Vserver
Selects the vserver for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of LUNs to display. The default setting is 25.
The following example displays LUN statistics:
cluster1::> statistics lun show
cluster1 : 12/31/2013 16:00:04
*Total Read Write Other   Read Write Latency
  Lun Vserver     Ops  Ops   Ops   Ops  (Bps) (Bps)    (ms)
 lun1     vs1     58   13    15    29 310585  3014      39
 lun0     vs2     56    0    11    45   8192 28826      47
