security dynamic-authorization group delete
Delete a Dynamic Authorization group
The security dynamic-authorization group delete command deletes the specified group.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the dynamic authorization group that is being deleted. If this parameter is specified, the setting applies to that Vserver only. If not specified, the cluster Vserver setting is used.
-name <text>- Group Name-
This parameter specifies the group name that is being deleted.
The following command deletes the group test from the Vserver vs1 .
cluster1::> dynamic authorization group delete -vserver vs1 -name test
