ONTAP commands
security dynamic-authorization executed-commands show
Display executed commands
The security dynamic-authorization executed-commands show command displays information about the executed commands according to the dynamic authorization rules.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the dynamic authorization executed commands.
[-vserver <vserver name>] - Vserver
Selects the dynamic authorization executed command fields that match this Vserver.
[-date <MM/DD/YYYY HH:MM:SS>] - Date
Selects the dynamic authorization executed command fields that match this date.
[-username <text>] - Username
Selects the dynamic authorization executed command fields that match this username.
[-operation <text>] - Operation
Selects the dynamic authorization executed command fields that match this operation.
[-count <integer>] - Count
Selects the dynamic authorization executed command fields that match this count.
[-score <integer>] - Trust Score
Selects the dynamic authorization executed command fields that match this score.
[-result {permit|deny|challenge}] - Result
Selects the dynamic authorization executed command fields that match this result.
The example below displays information about all dynamic authorization executed commands:
cluster1::> security dynamic-authorization executed-commands show
Vserver: usernamecluster-1
Date                  Operation   Username   Count   Trust Score   Result
12/7/2023 08:25:57    security login create
                                  admin      1       100           permit
12/7/2023 08:26:04    security login unlock
                                  admin      1       100           permit
12/7/2023 08:26:09    security multi-admin-verify approval-group create
                                  admin      1       100           permit
3 entries were displayed.
