system node coredump reports delete
Delete an application core report
The system node coredump reports delete
command deletes the specified application core report.
-node {<nodename>|local}
- Node That Owns the Coredump-
This specifies the node from which reports are to be deleted.
-reportname <text>
- Report Name-
This specifies the report that is to be deleted.
The following example shows how a report named notifyd.1894.80335005.2011-03-25.09_59_43.ucore.report is deleted from a node named node0:
cluster1::> system node coredump reports delete -node node0 -reportname notifyd.1894.80335005.2011-03-25.09_59_43.ucore.report
