volume efficiency off
Disables efficiency on a volume
The volume efficiency off command disables efficiency on a volume. Disabling efficiency is not supported on Capacity optimized Flash with QAT supported platforms.
-vserver <vserver name>- Vserver Name-
Specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name -
Specifies the name of the volume on which efficiency needs to be disabled.
-path </vol/volume>- Volume Path } -
Specifies the volume path on which efficiency needs to be disabled.
The following examples disable efficiency on a volume:
cluster1::> volume efficiency off -vserver vs1 -volume vol1
cluster1::> volume efficiency off -vserver vs1 -path /vol/vol1
