volume efficiency off
Disables efficiency on a volume
The volume efficiency off command disables efficiency on a volume. Disabling efficiency is not supported on Capacity optimized Flash with QAT supported platforms.
- -vserver <vserver name>- Vserver Name
Specifies the Vserver on which the volume is located.
- { -volume <volume name>- Volume Name
Specifies the name of the volume on which efficiency needs to be disabled.
- | -path </vol/volume>- Volume Path }
Specifies the volume path on which efficiency needs to be disabled.
The following examples disable efficiency on a volume:
cluster1::> volume efficiency off -vserver vs1 -volume vol1
cluster1::> volume efficiency off -vserver vs1 -path /vol/vol1
 PDFs
PDFs
