security dynamic-authorization rule delete
Delete a dynamic authorization rule
The security dynamic-authorization rule delete command deletes a custom dynamic authorization rule for an operation. It can be used to delete a custom dynamic authorization rule that was configured using the security dynamic-authorization rule create command.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver associated with the custom dynamic authorization rule.
-operation <Command or Command Directory>- Command or Command Directory-
This parameter specifies the operation for the custom dynamic authorization rule to be deleted.
The following command deletes a custom dynamic authorization rule for the network port ifgrp operation for the Administrative Vserver.
cluster1::> security dynamic-authorization rule delete -vserver cluster1 -operation "network port ifgrp"
The following command deletes a custom dynamic authorization rule for the vserver services nis-domain create operation for the data Vserver vs1.example.com .
cluster1::> security dynamic-authorization rule delete -vserver vs1.example.com -operation "vserver services nis-domain create"
