snaplock log show
Display audit log configuration.
The snaplock log show
command displays the following information about the SnapLock log infrastructure:
Vserver name
Volume name
Maximum log size
Default retention period
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter is specified, the command displays the log information for Vserveers that match the specified value.
[-volume <volume name>]
- Log Volume Name-
If this parameter is specified, the command displays the log configuration for volumes that match the specified value.
[-max-log-size {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Size of Log File-
If this parameter is specified, the command displays the log configuration with a matching
-max-log-size
value. [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Default Log Record Retention Period-
value.
cluster1::> snaplock log show -vserver vs1 Vserver Name : vs1 Log Volume Name : 15MB Maximum Size of Log File : 15MB Default Log Record Retention Period : 6 months
cluster1::> snaplock log show Vserver Volume Maximum Size Retention Period ----------------- ------------------- ------------------- -------------------- vs1 vol1 15MB 6 months
