vserver security file-directory ntfs sacl modify
Modify an NTFS security descriptor SACL entry
The vserver security file-directory ntfs sacl modify
command modifies parameters in an existing system access control list entry.
You can unambiguously define which SACL entry to modify by specifying the following four parameters in the modify command:
Vserver associated with the security descriptor that contains the SACL entry
Name of the security descriptor that contains the SACL entry
Whether the SACL is a success or failure type of SACL entry
The account name or SID to which the SACL is applied
You can modify the following parameters:
-rights,-advanced-rights,-rights-raw
-apply-to
-vserver <vserver name>
- Vserver-
Specifies the name of the Vserver associated with the security descriptor containing the system access control list entry whose fields you want to modify.
-ntfs-sd <ntfs sd name>
- NTFS Security Descriptor Name-
Specifies the name of the security descriptor that contains the system access control list entry that you want to modify.
-access-type {failure|success}
- Success or Failure-
Specifies whether the system access control list entry that you want to modify is a
failure
orsuccess
access audit type. -account <name or sid>
- Account Name or SID-
Specifies the account on which to apply the system access control list entry. You can specify the account by using a user name or SID. You can use any of the following formats when specifying the value for this parameter:
* SID
* Domain\user-name
* user-name@Domain
* user-name@FQDNIf you specify any of the three user name formats for the value of -account
, keep in mind that the value for the user name is case insensitive. - {
[-rights {no-access|full-control|modify|read-and-execute|read|write}]
- Access Rights -
Specifies the rights that you want to get audited for the account specified in the
-account
parameter. The-rights
parameter is mutually exclusive with the-advanced-rights
and-rights-raw
parameter. If you specify the-rights
parameter, you can only specify one value.You can specify one of the following rights values:
no-access
full-control
modify
read-and-execute
read
write
[-rights-raw <Hex Integer>]
- Raw Access Rights (privilege: advanced) -
Specifies the raw rights that you want to get audited for the account specified in the
-account
parameter. The-rights-raw
and-rights
parameter. Specify the value as a hexadecimal integer, for example:0xA10F
or0xb3ff
etc. - |
[-advanced-rights <Advanced access right>,…]
- Advanced Access Rights } -
Specifies the advanced rights that you want to get audited for the account specified in the
-account
parameter. The-advanced-rights
parameter is mutually exclusive with the-rights
and-rights-raw
parameter. You can specify more than one advanced-rights value by using a comma-delimited list.You can specify one or more of the following advanced rights:
read-data
write-data
append-data
read-ea
write-ea
execute-file
delete-child
read-attr
write-attr
delete
read-perm
write-perm
write-owner
full-control
[-apply-to {this-folder|sub-folders|files}]
- Apply SACL To-
Specifies where to apply the system access control list entry. You can specify more than one value by using a comma-delimited list.
You can specify one or more of the following values:
this-folder
sub-folder
files
Select one of the following combinations of values for the -apply-to
parameter for Storage-Level Access Guard (SLAG):-
this-folder, sub-folder, files
files
If you specify an invalid
-apply-to
value, this security descriptor is removed from the associated Storage-Level Access Guard (SLAG)security file-directory policy task
The following example modifies the rights and -apply-to fields in the SACL entry.
cluster1::> vserver security file-directory ntfs sacl modify -ntfs-sd sd2 -access-type success -account BUILTIN\Administrators -vserver vs1 -rights modify -apply-to this-folder,sub-folders cluster1::> vserver security file-directory ntfs sacl show -vserver vs1 -ntfs-sd sd2 -account BUILTIN\Administrators -instance Vserver: vs1 Security Descriptor Name: sd2 Access type for Specified Access Rights: success Account Name or SID: BUILTIN\Administrators Access Rights: modify Advanced Access Rights: - Apply To: this-folder, sub-folders Access Rights: modify
