statistics port fcp show
FCP port interface throughput and latency metrics
This command continuously displays performance data for FCP ports at a regular interval. The command output displays data in the following columns:
Port - port name.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
[-port <text>]
- Port-
Selects the port for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies the maximum number of ports to display. The default setting is 25.
The following example displays port statistics:
cluster1::> statistics port fcp show cluster1 : 12/31/2013 16:00:04 *Total Read Write Port Ops Ops Ops ----- ------ ---- ----- port1 2 2 0 port2 3 0 3 [...]
