vserver nfs tls interface show
Display the TLS configurations of NFS servers
The vserver nfs tls interface show command displays information about TLS configurations for NFS. The command output depends on the parameters specified with the command. If you do not specify any parameters, the command displays the following information about all TLS configurations for NFS:
Vserver name
Logical interface name
Logical interface IP address
Whether TLS is enabled or disabled
The TLS certificate name
The TLS certificate UUID
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about TLS configurations for NFS that are enabled, run the command with the -status enabled parameter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver
If you specify this parameter and the -lifparameter, the command displays information only about the TLS configuration or configurations for NFS that are associated with the specified Vserver and logical interface.
- [-lif <text>]- Logical Interface
If you specify this parameter and the -vserverparameter, the command displays information only about the TLS configuration or configurations for NFS that are associated with the specified logical interface and Vserver.
- [-address <IP Address>]- IP Address
If you specify this parameter, the command displays information only about the TLS configurations for NFS that are associated with the specified logical-interface IP address.
- [-status {enabled|disabled}]- TLS Status
If you specify this parameter, the command displays information only about the TLS configurations for NFS that match the specified value.
- [-certificate-name <text>]- TLS Certificate Name
- [-certificate-uuid <UUID>]- TLS Certificate UUID
If you specify this parameter, the command displays information only about the TLS configuration for NFS that match the specified value.
The following example displays information about the TLS configuration for NFS associated with the Vserver vs0 and the logical interface datalif1:
vs1::> vserver nfs tls interface show -vserver vs0 -lif datalif1
             Vserver: vs0
   Logical Interface: datalif1
          IP Address: 192.0.2.130
          TLS Status: enabled
TLS Certificate Name: vs0_17A014E1FA994582
TLS Certificate UUID: d1905777-98e8-11ee-aa96-005056bb844f
 PDFs
PDFs
