ONTAP commands
system controller ioxm show
Displays IOXM Device Health Status
The system controller ioxm show command displays the details of the IO expansion modules (IOXMs) that are connected to the nodes in a cluster. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about the IOXMs:
  • Node name
  • Display name
  • Is IOXM present?
  • Power status
  • Health monitor status
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information for all the IOXMs.
[-node {<nodename>|local}] - Node
Selects the IOXM that is connected to the specified node.
[-chassis-config {c-i|c-c|c-b}] - Controller-IOXM or Controller-Controller or Controller-Blank
Selects the IOXMs with the specified chassis configuration.
[-is-present {present|not-present}] - IOXM Presence
Selects the IOXMs that are connected and detected (present ) or connected but not detected (not-present ).
[-power {good|bad}] - Power to IOXM
Selects the IOXMs with the specified power state.
[-display-name <text>] - Display Name
Selects the IOXMs with the specified display name.
[-unique-name <text>] - Unique Name
Selects the IOXM with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Health Monitor Name
Selects the IOXMs with the specified health monitor.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - IOXM Health
Selects the IOXMs with the specified health monitor status.
The example below displays the information of all the IOXMs that are connected to the nodes in a cluster.
cluster1::> system controller ioxm show
Node          Display Name Is-Present? Power     Status
node1         IOXM         present     good      ok
node2         IOXM         present     good      ok
The example below displays detailed information of an IOXM that is connected to a node.
cluster1::> system controller ioxm show -instance -node node1
Node: node1
Controller-IOXM or Controller-Controller or Controller-Blank: c-i
      IOXM Presence: present
      Power to IOXM: good
       Display Name: node1/IOXM
        Unique Name: 8006459930
Health Monitor Name: controller
        IOXM Health: ok
