vserver consistency-group create
Create a new consistency group
The vserver consistency-group create command can be used to create a consistency group using existing consistency groups or volumes, or by creating new volumes.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver in which the consistency group is to be created.
-consistency-group <text>- Consistency Group Name-
This parameter specifies the name of the consistency group which is to be created.
[-parent-consistency-group <text>]- Parent Consistency Group Name-
This parameter specifies the name of the existing parent consistency group in which the consistency group is to be created. If the parent consistency group does not exist, it will be created.
[-storage-service <text>]- Storage Service-
This parameter specifies the storage service name. If not specified, the default value is the most performant for the platform.
[-qos-policy <text>]- QoS Policy Group-
This parameter specifies the QoS policy to be applied to the consistency group during creation.
[-tiering-placement-rules <FabricPool Placement Preferences>]- Tiering Placement Rules-
This parameter specifies the storage tiering placement rules for the consistency group.
[-tiering-policy <Tiering Policy>]- Tiering Policy-
This parameter specifies the tiering policy to be applied to the consistency group during creation.
[-object-stores <text>,…]- Object Store Name-
This parameter specifies the remote object stores to used for placement.
[-snapshot-policy <snapshot policy>]- Snapshot Copy Policy-
This parameter specifies the Snapshot policy to be applied to the consistency group during creation.
[-application-type <Application type for the parent or top level CG>]- Application Type -
This parameter specifies the application type for the parent consistency group.
[-application-component-type <Application component type for child CG>]- Application Component Type } -
This parameter specifies the application component type of the child consistency group.
[-consistency-groups <text>,…]- Consistency Groups -
This parameter optionally specifies a comma separated list of existing consistency groups under the Vserver.
[-volumes <text>]- Volume Names -
This parameter specifies a filter to choose any existing volumes in the Vserver to add to the new consistency group.
[-volume-prefix <volume name>]- Volume Name Prefix -
This parameter specifies a volume prefix to be added to the volume name for new volumes created in the new consistency group.
[-volume-count <integer>]- Number of Volumes to Create }-
This parameter specifies the number of new volumes to be created in the new consistency group.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Provisioned Size-
This parameter specifies the size of each new volume that is to be created in the consistency group. If
-lunor-namespaceparameter is specified, this refers to the size of each LUN or namespace. - {
[-lun <text>]- LUN Name -
This parameter specifies the name of the LUN to be created in the consistency group. If the
-lun-countparameter is specified this field is treated as prefix. [-lun-count <integer>]- Number of LUNs to Create-
This parameter specifies the number of new LUNs to be created in the consistency group.
[-lun-os-type <LUN Operating System Format>]- LUN Operating System Type-
This parameter specifies the OS type for the new LUNs.
[-igroup <text>]- iGroup Name-
This parameter specifies the name of the initiator group.
[-namespace <text>]- Namespace Name -
This parameter specifies the name of the namespace to be created in the consistency group. If the
-namespace-countparameter is specified this field is treated as prefix. [-namespace-count <integer>]- Number of Namespaces to Create-
This parameter specifies the number of new namespaces to be created in the consistency group.
[-namespace-os-type {aix|linux|vmware|windows}]- NVME Operating System Type-
This parameter specifies the OS type for the new namespaces.
[-subsystem <text>]- Subsystem Name-
This parameter specifies the name of the nvme subsystem.
[-export-policy <text>]- Export Policy Name -
This parameter specifies the name of the export policy to be associated with the newly created volumes.
[-nas-gid <integer>]- NAS Group ID-
This parameter specifies the UNIX group ID of the newly created volumes.
[-nas-path <text>]- Junction Path-
This parameter specifies the mount path for the newly created volumes.
[-nas-junction-parent-volume <volume name>]- Junction Parent Volume Name-
This parameter specifies the name of the parent volume that contains the junction inode of this volume.
[-nas-security-style <security style>]- NAS Security Style-
This parameter specifies the security style associated with the newly created volumes.
[-nas-uid <integer>]- NAS User ID-
This parameter specifies the UNIX user ID of the newly created volumes.
[-nas-unix-permissions <unix perm>]- NAS UNIX Permissions-
This parameter specifies the UNIX permissions for the newly created volumes.
[-cifs-share <Share>]- Volume CIFS Share Name-
This parameter specifies the name of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-user-or-group <text>]- CIFS User/Group Name-
This parameter specifies the ACL user or group of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-win-unix-id <text>]- Windows SID or UNIX ID-
This parameter specifies the ACL windows or unix id of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-type {windows|unix-user|unix-group}]- CIFS User or Group Type-
This parameter specifies the ACL type of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-permission <access rights>]- CIFS Access Type }-
This parameter specifies the ACL permission of the CIFS share for each volume in the new consistency group.
+ The following command creates a new parent consistency group parentcg with existing consistency groups cg1 and cg2.
cluster1::> vserver consistency-group create -consistency-group parentcg -consistency-groups cg1,cg2
(vserver consistency-group create)
[Job 32] Job succeeded: Success
+ The following command creates a new consistency group singlecg with existing volumes vol1 and vol2.
cluster1::> vserver consistency-group create -consistency-group singlecg -volumes vol1,vol2
[Job 33] Job succeeded: Success
+ The following command creates a new consistency group singlecg with two new volumes each of size 1gb and volume name prefix with db_vols.
cluster1::> vserver consistency-group create -consistency-group singlecg -volume-prefix db_vols -volume-count 2 -size 1gb
[Job 34] Job succeeded: Success
+ The following command creates a new consistency group singlecg2 with two new volumes each of size 1gb and volume name prefix with db_vols and a snapshot policy of default and application-type mongodb.
cluster1::> vserver consistency-group create -consistency-group singlecg -volume-prefix db_vols -volume-count 2 -size 1gb -snapshot-policy default -application-type mongodb
[Job 35] Job succeeded: Success
+ The following command creates a new consistency group child1 under existing parent consistency group parent1 and create two new volumes each of size 1gb.
cluster1::> vserver consistency-group create -consistency-group child1 -parent-consistency-group parent1 -volume-count 2 -size 1gb
[Job 36] Job succeeded: Success
+ The following command creates a new consistency group child2 under existing parent consistency group parent2 and creates two new volumes each of size 1gb and volume name prefix with child2_volumes.
cluster1::> vserver consistency-group create -consistency-group child2 -parent-consistency-group parent2 -volume-prefix child2_volumes -volume-count 2 -size 1gb
[Job 37] Job succeeded: Success
+ The following command creates a new consistency group child3 under existing parent consistency group parent2 and creates two new volumes vol1 and vol2 each of size 1gb.
cluster1::> vserver consistency-group create -consistency-group child3 -parent-consistency-group parent2 -volumes vol1,vol2 -size 1gb
[Job 38] Job succeeded: Success
+ The following command creates a new consistency group singlecg with two new volumes each of size 1gb and volume name prefix with db_vols and CIFS share share1 and ACL properties.
cluster1::> vserver consistency-group create -consistency-group singlecg -volume-prefix db_vols -volume-count 2 -size 1gb -cifs-share share1 -cifs-share-acl-type windows -cifs-share-acl-user-or-group Everyone -cifs-share-acl-permission Read -nas-path "/vol"
[Job 39] Job succeeded: Success
