vserver iscsi interface accesslist show
Show accesslist of the initiators for iSCSI connectivity
This command displays an access list for an initiator. An access list is a list of logical interfaces that an initiator can use for iSCSI logins. The system records the access lists as part of the node configuration and preserves the access lists during reboots.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to display the access lists that match the Vserver name that you specify.
[-initiator-name <text>]
- Initiator Name-
Use this parameter to display the access lists that match the initiator that you specify.
[-lif <lif-name>]
- Logical Interface-
Use this parameter to display the access lists that match the logical interface that you specify.
cluster1::> vserver iscsi interface accesslist show -vserver vs1 Vserver Initiator Name Logical Interface ------------------ ----------------------------- ----------------------------- vs1 iqn.2010-01.com.example:aaaaa isw1 isw2 iqn.2010-01.com.example:aaabb isw1 isw2 4 entries were displayed.
Displays the access lists for vserver vs1.
