Command reference
vserver iscsi interface accesslist show
Show accesslist of the initiators for iSCSI connectivity
This command displays an access list for an initiator. An access list is a list of logical interfaces that an initiator can use for iSCSI logins. The system records the access lists as part of the node configuration and preserves the access lists during reboots.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to display the access lists that match the Vserver name that you specify.
[-initiator-name <text>] - Initiator Name
Use this parameter to display the access lists that match the initiator that you specify.
[-lif <lif-name>] - Logical Interface
Use this parameter to display the access lists that match the logical interface that you specify.
cluster1::> vserver iscsi interface accesslist show -vserver vs1
Vserver            Initiator Name                Logical Interface
vs1                iqn.2010-01.com.example:aaaaa isw1
                                                 isw2
                   iqn.2010-01.com.example:aaabb isw1
                                                 isw2
4 entries were displayed.
Displays the access lists for vserver vs1.
