system license show-serial-numbers
Display History of Serial Numbers
This command displays the history of changes to the support and node serial numbers. The node serial number and the support serial number of an ONTAP system are generally the same and do not change over time. However, when capacity pools licensing is used, the support serial number is that of the capacity pool license serial number and the node serial number is generated by the license manager. Also, when a cluster is upgraded or converted from capacity tiers licensing to capacity pools licensing, its support serial numbers as well as its node serial numbers change.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-seqnum <Sequence Number>]
- Sequence number-
Event sequence number
[-node {<nodename>|local}]
- Node-
Selects the node names that match this parameter value.
[-date <MM/DD/YYYY HH:MM:SS>]
- Date-
Selects the dates of serial number changes that match this parameter value.
[-reason <text>]
- Reason for change-
Reasons for serial number changes.
[-support-serial-number <text>]
- Support Serial Number-
Selects the support serial numbers that match this parameter value.
[-node-serial-number <text>]
- Node Serial Number-
Selects the node serial number that match this parameter value.
The following example displays the serial number change history of a four node capacity pools cluster. Its two HA pairs were originally assigned to capacity pools 390000101 and 390000102, and then both were reassigned to another capacity pool 390000103:
cluster1::> system license show-serial-numbers Change Date: 06/06/2019 Reason: Reassignments of capacity pools Node Support Serial Node Serial --------------- -------------------- -------------------- node1 390000103 99939000010100000001 node2 390000103 99939000010100000002 node3 390000103 99939000010200000003 node4 390000103 99939000010200000004 Change Date: 03/01/2019 Reason: Initial installation Node Support Serial Node Serial --------------- -------------------- -------------------- node1 390000101 99939000010100000001 node2 390000101 99939000010100000002 node3 390000102 99939000010200000003 node4 390000102 99939000010200000004
The following example displays the history of a four node cluster converted from capacity tiers licensing to capacity pools licensing:
cluster1::> system license show-serial-numbers Change Date: 06/06/2019 Reason: Conversions from capacity tiers to pools Node Support Serial Node Serial --------------- -------------------- -------------------- node1 390000103 99939000010300000011 node2 390000103 99939000010300000012 node3 390000103 99939000010300000013 node4 390000103 99939000010300000014 Change Date: 03/01/2019 Reason: Initial installation Node Support Serial Node Serial --------------- -------------------- -------------------- node1 310000101 310000101 node2 310000102 310000102 node3 310000103 310000103 node4 310000104 310000104
The following example displays the history of an evaluation cluster that was upgraded to capacity pools licensing:
cluster1::> system license show-serial-numbers Change Date: 06/06/2019 Reason: Conversions from capacity tiers evaluation to pools Node Support Serial Node Serial --------------- -------------------- -------------------- node1 390000103 99939000010300000011 node2 390000103 99939000010300000012 node3 390000103 99939000010300000013 node4 390000103 99939000010300000014 Change Date: 03/01/2019 Reason: Initial installation Node Support Serial Node Serial --------------- -------------------- -------------------- node1 evaluation 99887766554433221101 node2 evaluation 99887766554433221102 node3 evaluation 99887766554433221103 node4 evaluation 99887766554433221104
