vserver services access-check authentication sid-to-unix-name
Translate a Windows SID to a UNIX User Name
The vserver services access-check authentication sid-to-unix-name
translates a Windows SID to a UNIX Name.
[-node {<nodename>|local}]
- Node Name (privilege: advanced)-
The name of the node on which the command is executed.
-vserver <vserver>
- Vserver Name (privilege: advanced)-
The name of the Vserver.
-sid <text>
- Windows SID (privilege: advanced)-
The Windows SID which is to be translated to the corresponding UNIX name.
This example translates a Windows SID on node "node2" and returns the corresponding UNIX name.
cluster1::vserver services access-check*> sid-to-unix-name -node node2 -vserver vs1 -sid S-1-5-21-1407423728-2963865486-1834115207-500 SID Type: User UNIX Name: test Domain Name: TESTDOMAIN Windows Name: test
