storage shelf drawer show
Display a list of drawers
The storage shelf drawer show
command displays information for storage shelf drawers in the storage system. If no parameters are specified, the default command displays the following information for the drawers:
Shelf Name
Drawer Number
Status
Closed/Open
Disk Count
Firmware
To display detailed information for a single drawer, use the -shelf
and -drawer
parameters.
[-fields <fieldname>,…]
Displays the specified fields for all drawers, in column style output.
[-errors ]
Displays the following error status information about the drawers that have errors:
Status
Error Description
[-instance ]
Displays expanded information for all drawers in the system. If a shelf and drawer are specified, then this parameter displays the same detailed information for the specified drawer as does the -shelf and -drawer parameters.
[-shelf <text>]
- Shelf Name-
Displays the drawers in the storage shelf that matches the specified shelf name.
[-drawer <integer>]
- Drawer Number-
Displays the drawers that match the specified drawer number.
[-node {<nodename>|local}]
- Node Name-
Displays the drawers that are present for the specified node.
[-disk-count <integer>]
- Drawer Disk Count-
Displays the drawers that have the specified disk count.
[-part-number <text>]
- Part Number-
Displays the drawers that have the specified part number.
[-serial-number <text>]
- Serial Number-
Displays the drawer that matches the specified serial number.
[-is-closed {open|closed}]
- Drawer is Closed?-
Displays the drawers that are closed or open.
[-firmware-a <text>]
- Firmware A-
Displays the the drawers for which module A has the specified firmware version.
[-firmware-b <text>]
- Firmware B-
Displays the drawers for which module B has the specified firmware version.
[-path-a {unknown|ok|degraded|none}]
- Path A-
Displays the drawers for which module A has the specified path status.
[-path-b {unknown|ok|degraded|none}]
- Path B-
Displays about drawers for which module B has the specified path status.
[-is-supported {yes|no}]
- Drawer is Supported?-
Displays the drawers that are supported (TRUE) or not supported (FALSE).
[-vendor <text>]
- Vendor Name-
Displays the drawers that match the specified vendor.
[-mfg-date <text>]
- Mfg. Date-
Displays the drawers that match the specified manufactured date.
[-fru-type <text>]
- FRU Type-
Displays the drawers that match the specified FRU type.
[-status-a {unknown|normal|warning|error|critical}]
- Status A-
Displays the drawers with module A currently operating under the specified status.
[-status-b {unknown|normal|warning|error|critical}]
- Status B-
Displays the drawers with module B currently operating under the specified status.
[-error <text>]
- Error-
Displays the drawers that match the specified error description.
The following example displays information about all drawers:
cluster1::> storage shelf drawer show Drawer Disk Shelf Drawer Status A/B Closed? Count Firmware A/B ----- ------ ----------------- ------- ----- ----------------- 2.5 1 normal/normal closed 4 00000634/00000634 2 normal/normal closed 4 00000634/00000634 3 normal/normal closed 4 00000634/00000634 4 normal/normal closed 5 00000634/00000634 5 normal/normal closed 4 00000634/00000634 5 entries were displayed. cluster1::>
The following example displays expanded information about drawer 1 in shelf 2.5:
cluster1::> storage shelf drawer show -shelf 2.5 -drawer 1 Shelf: 2.5 Drawer ID: 1 Part Numer: 111-03071 Serial Number: 021604008153 Drawer is Closed?: closed Disk Count: 4 Firmware A: 00000634 Firmware B: 00000634 Path A: ok Path B: ok Status A: normal Status B: normal Drawer is Supported?: yes Vendor Name: NETAPP Mfg. Date: 02/2016 FRU Type: SASDRWR Error Description: - cluster1::>
The following example displays error information about the drawers that have errors:
cluster1::> storage shelf drawer show -errors Shelf Drawer Status A/B Error Description ----- ------ ----------------- ----------------------------------------------- 2.5 2 warning/warning Drawer open. cluster1::>
