security key-manager external aws disable
Disable AWS KMS
This command disables the Amazon Web Service Key Management Service (AWSKMS) associated with the given Vserver. AWSKMS cannot be disabled if it is in use by ONTAP. This command will fail if AWSKMS has not been enabled for the Vserver.
-vserver <Vserver Name>
- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver on which the AWSKMS is to be disabled.
The following example disables the AWSKMS for Vserver v1.
cluster-1::>security key-manager external aws disable -vserver v1
