statistics preset detail show
Display information about Performance Preset Details
Displays the specific details of each preset, including the objects sampled, the counter sample periods, and the counters sampled.
[-fields <fieldname>,…]
Selects which performance preset detail attributes to display.
[-instance ]
Displays all of the performance preset detail attributes.
[-preset <text>]
- Preset Name (privilege: advanced)-
Selects the performance preset details that match the specified preset name.
[-object <text>]
- Performance Object (privilege: advanced)-
Selects the performance preset details that match the specified object name.
[-sample-period <sample_period>]
- Archive Sample period (privilege: advanced)-
Selects the performance preset details that are collected at the specified sample period.
[-counter-set <text>,…]
- Performance Counter Name Set (privilege: advanced)-
Selects the performance preset details that match the specified counters in the counter set. Use "|" to separate multiple counters.
[-instance-filters <text>,…]
- Performance Instance Filters (privilege: advanced)-
Selects the performance preset details that match the specified instance filters. Use "|" to separate multiple instance filters. This field is reserved for future use.
cluster1::*> statistics preset detail show Sample Counter Instance Preset Name Object Period Set Filters ----------- ------------ ------ -------------- -------------------------------- asup-event aggregate 1w instance_name, - node_name, process_name, parent_host, total_ transfers, user_reads, user_writes, cp_reads, user_read_ blocks, user_write_ blocks, cp_read_ blocks, wv_fsid, wv_vol_type, wv_fsinfo_fs_ version, wv_volinfo_fs_ options, . . .
