statistics preset detail show
PDF of this doc site
Creating your file...
Display information about Performance Preset Details
Displays the specific details of each preset, including the objects sampled, the counter sample periods, and the counters sampled.
[-fields <fieldname>,…]
Selects which performance preset detail attributes to display.
[-instance ]
Displays all of the performance preset detail attributes.
[-preset <text>]
- Preset Name (privilege: advanced)-
Selects the performance preset details that match the specified preset name.
[-object <text>]
- Performance Object (privilege: advanced)-
Selects the performance preset details that match the specified object name.
[-sample-period <sample_period>]
- Archive Sample period (privilege: advanced)-
Selects the performance preset details that are collected at the specified sample period.
[-counter-set <text>,…]
- Performance Counter Name Set (privilege: advanced)-
Selects the performance preset details that match the specified counters in the counter set. Use "|" to separate multiple counters.
[-instance-filters <text>,…]
- Performance Instance Filters (privilege: advanced)-
Selects the performance preset details that match the specified instance filters. Use "|" to separate multiple instance filters. This field is reserved for future use.
cluster1::*> statistics preset detail show Sample Counter Instance Preset Name Object Period Set Filters ----------- ------------ ------ -------------- -------------------------------- asup-event aggregate 1w instance_name, - node_name, process_name, parent_host, total_ transfers, user_reads, user_writes, cp_reads, user_read_ blocks, user_write_ blocks, cp_read_ blocks, wv_fsid, wv_vol_type, wv_fsinfo_fs_ version, wv_volinfo_fs_ options, . . .
