storage tape trace
Enable/disable tape trace operations
This command enables or disables diagnostic tape trace operations for all tape drives attached to the node you have specified.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which the tape trace feature is enabled or disbled.
[-is-trace-enabled {true|false}]
- Tape Trace Enabled or Disabled-
Use this parameter to enable or disable the tape trace feature. By default, the tape trace feature is enabled.
The following example enables tape trace operation on the node, cluster1-01.
cluster1::> storage tape trace -node cluster1-01 -is-trace-enabled true
