vserver peer permission create
Create a new Vserver peer permission
The vserver peer permission create
command creates a new Vserver peer permission that can be used during intercluster Vserver peer relationship creation. Once this permission exists for a local Vserver and peer cluster combination on local cluster, no explict vserver peer accept command is required for any incoming Vserver peer relationship creation request from a remote cluster for that local Vserver. Peer relationship directly changes state to peered
on both clusters.
-peer-cluster <text>
- Peer Cluster Name-
Specifies the name of the peer Cluster.
-vserver <text>
- Vserver Name-
Specifies the name of the local Vserver. Use "*" to create permission that applies for all local Vservers.
-applications {snapmirror|flexcache}
- Peering Applications-
Specifies the applications that can make use of the intercluster Vserver peer relationship.
The following example illustrates how to create Vserver peer permissions:
cluster1::> vserver peer permission create -peer-cluster cluster2 -vserver vs1 -applications snapmirror The following example illustrates how to create a Vserver peer permission that applies for all the local Vservers cluster1::> vserver peer permission create -peer-cluster cluster2 -vserver "*" -applications snapmirror Warning: This Vserver peer permission applies to all local Vservers. After that no explict "vserver peer accept" command required for Vserver peer relationship creation request from peer cluster "cluster2" with any of the local Vservers. Do you want to continue? {y|n}: y cluster1::> vserver peer permission show Peer Cluster Vserver Applications ---------------- --------------- ----------------- cluster2 "*" snapmirror cluster2 vs1 snapmirror 2 entries were displayed. Note that both all Vservers and any local Vserver name permission can exists at same time.
