vserver nfs kerberos realm delete
Delete a Kerberos realm configuration
The vserver nfs kerberos realm delete
command deletes a Kerberos realm configuration from the system.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for the Kerberos realm configuration that you want to delete.
-realm <text>
- Kerberos Realm-
This parameter specifies the name of the Kerberos realm for the configuration.
The following example deletes the Kerberos realm SEC.EXAMPLE.COM from the Vserver named AUTH:
cluster1::> vserver nfs kerberos realm delete -vserver AUTH -realm SEC.EXAMPLE.COM
