vserver cifs domain name-mapping-search modify
Modify the list of trusted domains for name-mapping search
The vserver cifs domain name-mapping-search modify
command modifies the current list of trusted domains to be used in preference to all others by the specified Vserver to lookup Windows user names when performing Windows user to UNIX user name-mapping. The new list overwrites the existing list. This command is not supported for workgroup CIFS servers.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for which you want to modify the trusted domain list.
-trusted-domains <domain name>,…
- Trusted Domains-
This parameter specifies a comma-delimited list of fully qualified domain names of the trusted domains of the home domain.
The following example modifies the trusted domain list used by Vserver vs1:
cluster1::> vserver cifs domain name-mapping-search modify -vserver vs1 -trusted-domains cifs3.example.com
