metrocluster configuration-settings interface delete
Delete a MetroCluster interface
The metrocluster configuration-settings interface delete
command deletes the network logical interface that was configured on a network port provisioned for MetroCluster.
This command cannot be run if the metrocluster configuration-settings connection connect command has set up the connections between the nodes in a DR group. The metrocluster configuration-settings connection disconnect command must then be run to remove the connections.
commands are run in the following order to remove the MetroCluster over IP configuration:
-cluster-name <Cluster name>
- Cluster Name-
Use this parameter to specify the name of the local or partner cluster.
-home-node <text>
- Home Node-
Use this parameter to specify the home node in the cluster which hosts the interface.
-home-port {<netport>|<ifgrp>}
- Home Port-
Use this parameter to specify the home port provisioned for MetroCluster.
The following example shows the deletion of interface in a MetroCluster setup:
clusA::> metrocluster configuration-settings interface delete -cluster-name clusA -home-node A1 -home-port e0f [Job 271] Job succeeded: Interface Delete is successful. clusA::> metrocluster configuration-settings interface show DR Config Group Cluster Node Network Address Netmask Gateway State ----- ------- ------- --------------- --------------- --------------- --------- 1 clusA A1 Home Port: e0g 10.140.113.215 255.255.192.0 - completed A2 Home Port: e0f 10.140.113.216 255.255.192.0 - completed Home Port: e0g 10.140.113.217 255.255.192.0 - completed clusB B2 Home Port: e0f 10.140.113.249 255.255.192.0 - completed Home Port: e0g 10.140.113.25 255.255.192.0 - completed B1 Home Port: e0f 10.140.113.218 255.255.192.0 - completed Home Port: e0g 10.140.113.248 255.255.192.0 - completed 7 entries were displayed. clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 ready for next interface create A2 ready for connection connect clusB B1 ready for connection connect B2 ready for connection connect 4 entries were displayed. Output of the command after deleting all the interfaces: clusA::> metrocluster configuration-settings interface show No interfaces exist. clusA::> metrocluster configuration-settings show-status Cluster Node Configuration Settings Status -------------------------- ------------------ --------------------------------- clusA A1 ready for interface create A2 ready for interface create clusB B1 ready for interface create B2 ready for interface create 4 entries were displayed.
