ONTAP commands
metrocluster configuration-settings interface delete
Delete a MetroCluster interface
The metrocluster configuration-settings interface delete command deletes the network logical interface that was configured on a network port provisioned for MetroCluster.
This command cannot be run if the metrocluster configuration-settings connection connect command has set up the connections between the nodes in a DR group. The metrocluster configuration-settings connection disconnect command must then be run to remove the connections.
The metrocluster configuration-settings commands are run in the following order to remove the MetroCluster over IP configuration:
-cluster-name <Cluster name> - Cluster Name
Use this parameter to specify the name of the local or partner cluster.
-home-node <text> - Home Node
Use this parameter to specify the home node in the cluster which hosts the interface.
-home-port {<netport>|<ifgrp>} - Home Port
Use this parameter to specify the home port provisioned for MetroCluster.
The following example shows the deletion of interface in a MetroCluster setup:
clusA::> metrocluster configuration-settings interface delete -cluster-name clusA -home-node A1 -home-port e0f
[Job 271] Job succeeded: Interface Delete is successful.
clusA::> metrocluster configuration-settings interface show
DR        Config
Group Cluster Node    Network Address Netmask         Gateway         State
1     clusA A1
                 Home Port: e0g
                      10.140.113.215  255.255.192.0   -               completed
                       A2
                 Home Port: e0f
                      10.140.113.216  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.217  255.255.192.0   -               completed
      clusB B2
                 Home Port: e0f
                      10.140.113.249  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.25   255.255.192.0   -               completed
                       B1
                 Home Port: e0f
                      10.140.113.218  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.248  255.255.192.0   -               completed
7 entries were displayed.
clusA::> metrocluster configuration-settings show-status
Cluster                    Node               Configuration Settings Status
clusA
                           A1                 ready for next interface create
                           A2                 ready for connection connect
clusB
                           B1                 ready for connection connect
                           B2                 ready for connection connect
4 entries were displayed.
Output of the command after deleting all the interfaces:
No interfaces exist.
clusA
                           A1                 ready for interface create
                           A2                 ready for interface create
clusB
                           B1                 ready for interface create
                           B2                 ready for interface create
