vserver vscan disable
Disable Vscan on a Vserver
The vserver vscan disable
command disables Vscan on a Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to disable Vscan.
The following example disables Vscan on Vserver vs1.
cluster1::> vserver vscan disable -vserver vs1 cluster1::> vserver vscan show -vserver vs1 Vserver: vs1 Vscan Status: off
