snapmirror snapshot-owner show
Display Snapshot Copies with Owners
The snapmirror snapshot-owner show
command is used to list all Snapshot copies with owners that were added using the snapmirror snapshot-owner create command.
[-fields <fieldname>,…]
If this parameter is specified, the command displays information about the specified fields.
[-instance ]
If this parameter is specified, the command displays detailed information about all fields.
-vserver <vserver name>
- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This parameter specifies the name of the volume.
[-snapshot <snapshot name>]
- Snapshot Copy Name-
If this parameter is specified, the command displays the owner name for the specified Snapshot copy.
The following example lists all Snapshot copies with owners on volume vol1
in Vserver vs0
. The system-generated default owner name is displayed as "-".
cluster1::> snapmirror snapshot-owner show -vserver vs0.example.com -volume vol1 Vserver Volume Snapshot Owner Names -------- -------------------- -------------------- -------------------- vs0.example.com vol1 snap2 - snap1 app1
The following example displays the owner name for Snapshot copy snap1
on volume vol1
in Vserver vs0.example.com
cluster1::> snapmirror snapshot-owner show -vserver vs0.example.com -volume vol1 -snapshot snap1 Vserver: vs0.example.com Volume: vol1 Snapshot: snap1 Owner Names: app1
