storage array rename
Change the name of a storage array in the array profile database.
The storage array rename
command permits substitution of the array profile name which Data ONTAP assigned during device discovery. By default, the name that Data ONTAP assigned to the storage array during discovery is shown in Data ONTAP displays and command output.
-name <text>
- Name-
Storage array name either generated by Data ONTAP or assigned by the user.
-new-name <text>
- The new name to assign to this array profile. (28 chars max)-
New name to assign to the storage array.
cluster1::> storage array rename -name HITACHI_DF600F_1 -new-name MyArray
